On Tue, 2006-10-24 at 13:43 +0900, Artem Kazakov wrote:
> Just if someone is interested, I'm using EPICS on Freebsd 6.x-amd64
> It just works fine. For now I have been playing with epics on FreeBSD
> for about 8 month and had no problem.
> So if anyone wants to use EPICS & FreeBSD I can share my "configure/*"
> files needed to build.
> Also, may be you can write somewhere on the web-page that EPICS &
> FreeBSD can work together :)
Are you running EPICS in pure 64-bit mode?
That is did you build EPICS as a 64-bit package or are you in 32-bit
mode?
If you are truly running pure 64-bit, you should run all of the
regression tests in EPICS BASE. Also, you should check the EPICS
extensions.
I have been running pure 64-bit EPICS on RHEL WS4 AMD64 for about 8
months as well.
All of the regression tests pass for me.
The main problem I have now is with some of the EPICS extensions at run
time.
--- alh (seg faults at run time)
--- StripTool (seg faults)
--- EDM (works)
--- probe (works)
--- Channel Archiver (works)
Ernest
> Tyoma.
- Re: R 3.14.8.2 on FreeBSD 6.x amd64 Artem Kazakov
- R 3.14.8.2 on FreeBSD 6.x amd64 Artem Kazakov
problem about importing sca to delphi marco_hair
<2006>
2025
<2006>
2025
