1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Device Driver question
To: <[email protected]>
Date: Tue, 31 Oct 2006 10:07:21 -0600
I'm working on some optimization for my Modbus Serial driver, and have a question.
>From the talk on Device Support is says that the DSET - initialize routine, when passed a parameter of 1, "Can be used as a final startup step.  All device address information is now known."
Does this imply that once the iocinit() routine has called the initialize routine with the parameter of 1, I can infer that no additional I/O items could be defined?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: EPICS Device Driver question Andrew Johnson
Prev: RTEMS now on IOC 9010 Blade and new 4 PMC Slot Version Darrell Nineham
Next: Re: EPICS Device Driver question Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
