Almost got the question entirely answered. Just one more thing:
Once the initialize routine is executed, can additional records be added? For instance, can an additional I/O item by defined? I'm not giving access to change addresses, but can I also infer that you can't add or delete any?
David Dudley
>>> Andrew Johnson <[email protected]> 10/31/2006 10:51 AM >>>
Hi David,
David Dudley wrote:
> From the talk on Device Support is says that the DSET - initialize
> routine, when passed a parameter of 1, "Can be used as a final
> startup step. All device address information is now known."
> Does this imply that once the iocinit() routine has called the
> initialize routine with the parameter of 1, I can infer that no
> additional I/O items could be defined?
Unless you're providing the ability to change addresses at runtime (by
implementing Extended Device Support, see the R3.14.8.2 iocAppDevGuide
section 12.5 for details) the answer is yes. The full initialization
order for a device support is
1. For all dsets, call dset->init(0)
2. For all records, call rset->init_record(prec, 0) which in turn calls
dset->init_record(prec, 0)
3. For all records, if a dsxt was registered call dsxt->add_record(prec)
4. For all records, call rset->init_record(prec, 1) which in turn calls
dset->init_record(prec, 1)
5. For all dsets, call dset->init(1)
If you don't register a dsxt during your dset->init(0) call then it is
not possible to change the record's INP/OUT field at runtime so your
inference would be correct.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- Re: EPICS Device Driver question Andrew Johnson
<2006>
2025
<2006>
2025
