I check the source code, in the file pvFactory/pv_register.cc, the function of create_StripClassPtr was commented out(version 1-11-). while in edm version 1-10-xx, it's NOT commented out. why? If I want to compile version 1-10-xx, it has errors like following: ../../../../lib/linux-x86//libEdmBase.so: undefined reference to `activeGraphicClass::crawlerGetNextPv()' ../../../../lib/linux-x86//libEdmBase.so: undefined reference to `activeGraphicClass::doActions(XButtonEvent*, int, int)' ../../../../lib/linux-x86//libEdmBase.so: undefined reference to `activeGraphicClass::crawlerGetFirstPv()' I try to grep where is "activeGraphicClass::crawlerGetNextPv()", but can't find it. ps, I am trying to run edm on fedora core 3. ======= At 11-04-2006, 13:54:53 you wrote: ======= >Hi, > I am trying to use edm to draw a StripChart in Monitors menu, then the edm crashed and gave a message like following: >/usr/local/epics/extensions/src/edm/pvFactory/O.linux-x86/libPV.so: undefined symbol: create_StripClassPtr >Segmentation fault > >Has anyboy used StripChart of edm before, could you give me some suggestions? >Ps, my edm version is 1-1-0m. also I have tried compiling several versions of edm. > > >Best wishes >Geyang 2006/11/4 = = = = = = = = = = = = = = = = = = = = Best regards Geyang 11-04-2006 K a p p a \ A N D 1 \ R e e b o k 全 长 场 99 元 耐 克\ 阿 迪 \ 李 宁 … 所 有 运 动 单 品 1 9 9 元 封 顶 , 限 时 抢 购 啦 !
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
