1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Motion control failure at APS
To: "Ron Sluiter" <[email protected]>, "EPICS" <[email protected]>
Cc: <[email protected]>
Date: Mon, 13 Nov 2006 12:56:34 -0600
Folks,
We have seen failures in the past where a motor moved constantly at a
slow rate right past limit switches on an OMS58.  It happened only on a
single axis, not on all 8 axes.
One way that this can happen is if there is noise pickup on the pulse
output line between the OMS58 and the driver module.  When that happens
the driver will move the motor, and the limit switches will not help,
since the drivers typically ignore the limits, and the controller is not
actually outputting the pulses.
The only solution to preventing disaster in that case is to set the hard
stops to a safe location.  In the case of 34ID-A I really think the hard
stops should have been set to prevent the bellows from moving enough to
be struck by the white x-ray beam.  Limit switches are never totally
reliable ...
> -----Original Message-----
> From: Ron Sluiter [mailto:[email protected]]
> Sent: Monday, November 13, 2006 12:12 PM
> To: EPICS
> Subject: Motion control failure at APS
> On Tuesday, July 25, a serious motion control failure
> occurred in the 34ID-A hutch here at the APS.
> All eight stepper motors controlled by a single Oregon
> Micro Systems (OMS) VME58 board ran past their limit
> switches and into their mechanical stops.
> The eight stepper motors involved in the accident are
> used to position two white beam slits and a mirror.
> Bellows up stream from the 1st white beam slit were
> punctured by the x ray beam.  Vacuum was lost.
> Additional damage included two broken limit switches
> and an ion pump.
> Three days of beamtime were lost.
> Like all APS beamlines using the OMS motor controllers,
> this IOC relies on the OMS controller to stop motion
> when a motor is moving in the direction of an activated
> limit switch.  In this case, not only did the OMS
> controller fail to stop motion when the limit switches
> were activated, the controller entered a strange failure
> mode that drove the motors into their mechanical stops.
> The VME crate in question is located inside the 34ID-A
> white-beam hutch. It is possible that radiation damage
> contributed to the failure of the OMS VME58 controller.
> There are hundreds of OMS boards at APS that have been in
> operation for many years, and no report of this type of
> failure has ever been made.  OMS has also never had
> a report of this type of failure.
> Between Kurt Goetze, OMS and myself; we have determined
> that the failure resulted from two characteristics of
> the OMS VME58 board, that, together conspired to cause
> this failure.  First, we have known for some time that
> the OMS VME58 boards output a step pulse on every axis
> after a VMEbus reset.  Second, (unknown to us) the
> on-board VME58 watchdog can cause the board to go into
> a continuous reset cycle if there is a board failure.
> These two characteristics, together, caused the failed
> VME58 board at 34ID-A to step all eight of its' motors at
> approximately 4 steps per second until power was shut off.
> Since this accident OMS has resolved the "step pulse on
> reset" problem.  By fixing the "step pulse on reset" problem,
> OMS prevents the VME58 from accidentally driving its' motors
> if a board fails and exhibits the "continuous reset" behavior.
> The "fix" requires the replacement of nine socketed
> components on the VME58 controller board.
> OMS is providing two ways to retrofit VME58 boards with
> this fix.
> Option #1 - Send your VME58 boards back to OMS.  They will
> replace the nine components and retest the board.  To do
> this, first contact OMS for a Return Materials Authorization
> (RMA) number and refer to Engineering Waver #112 (EW112)
> as the reason for the RMA. Cost is $357.00 per board.
> Option #2 - OMS is providing a retrofit kit that includes
> the nine parts (5 of which are pre-programmed), labeling,
> instructions and shipment for $107 per kit.
> I don't have the specifics on how to order the kit.  I will
> post that info. in a follow-up message.
> If you are ordering new OMS VME58 boards, be aware that OMS
> will not be incorporating the upgrade chip set unless you
> specify Engineering Waiver no. 112 (EW112) in your order.
> In addition, we recommend the MAXv rather than the VME58
> for new orders.
> For those who choose to upgrade existing VME58 boards,
> I strongly advise option #1.  Option #2 opens you to the
> risk of taking a perfectly functioning VME58 board and
> making it less reliable; e.g., bending a pin while inserting
> a part in a socket or damage from static discharge. Option
> #1 provides full testing and quality assurance from OMS.
> Closing thoughts;
> - Thanks to OMS for addressing and fixing this problem.
> The VME58 product family is approaching it's end of life.
> The only incentive for OMS to devote resources to resolving
> this problem is their commitment to quality.
> - The "step on reset" problem does not occur in OMS's
> latest controller; the MAXv and MAXp controllers.
> - OMS VME58 user's should review what the consequences of
> having this failure occur at their facilities would be.
> The decision to have your boards retrofitted should strike
> a balance between the probability of board failure (higher
> if exposed to radiation) and the consequences of that
> failure.
> Sorry for the length; hope I didn't bore you,
> Ron
Re: Motion control failure at APS Marty Smith
RE: Motion control failure at APS Emmanuel Mayssat
Prev: Motion control failure at APS Ron Sluiter
Next: Re: Motion control failure at APS Marty Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Motion control failure at APS - Not a Problem for Hytec 8601 / 8909 Darrell Nineham
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
