1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Scaling Database entries
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Mon, 13 Nov 2006 20:22:06 -0600
Device support must have a "convert" routine that does a calculation like the following to compute .ESLO and .EOFF
        precord->eslo = (eguf - egul)/(deviceHigh - deviceLow);
        precord->eoff = (deviceHigh*egul - deviceLow*eguf)/
Sent: Mon 11/13/2006 8:07 PM
To: [email protected]
Subject: Scaling Database entries
OK guys,
My modbus driver is starting to work, and now I'm linking up with some of the PLC's in the plant.  Now, I've started working on building the database for the first site.
Here's my question:
I've got some AI signals that come from one of the PLCs.  Raw values on some are scaled 0-32000, while others are scaled 800-32000, and others have raw values from -32768-32767.  I see the definitions for the EGUL and EGUF values, but how do I set the RAW input ranges?  Also, I've got some flow meter values that have to be scaled from linear to square root values..
David Dudley
City of Corpus Christi
Scaling Database entries David Dudley
Prev: Scaling Database entries David Dudley
Next: RE: devSNMP: Thread error? Kagarmanov, Albert
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Scaling Database entries David Dudley
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
