Kagarmanov, Albert wrote: This is not a real error, it's warning from Actually it is an error, in the epicsSnmpInit() code. It looks like 10000 stack-size is small enough for your Linux (See http://docs.sun.com/app/docs/doc/816-5137/6mba5vpja?a=view for detail) The stackSize parameter to the epicsThreadCreate() call should not be a number as the sizes needed can be different on different architectures. The epicsSnmpInit() function should be passing epicsThreadGetStackSize() one of three values epicsThreadStackSmall, epicsThreadStackMedium or epicsThreadStackBig according to how much stack the thread is expected to need, and using the return value from epicsThreadGetStackSize() as the parameter to epicsThreadCreate(). As an example, here's an excerpt from base/src/db/callback.c: callbackTaskId[ind] = epicsThreadCreate(taskName, priority, epicsThreadGetStackSize(epicsThreadStackBig), (EPICSTHREADFUNC)callbackTask, &priorityValue[ind]); By using this approach, the problem should not arise in the future as a new architecture with a bigger or smaller stack requirement that gets added to Base can adjust the absolute amount of memory allocated to the three sizes. My appologies if the wording in RELEASE_NOTES.html was confusing, and the Application Developers Guide entry for epicsThreadCreate() probably didn't help much either; I have just revised both documents. - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
