Some various points concerning the use of Irmis : - When I run several times the pv-crawler with --force option, it adds new lines into the ioc_boot table so that when searching through the idt:pv within the history mode, the same boot date appears several times although I think that it should appear only once. Am I right and, if so, is there a way to avoid that ? - If I move one PV from one IOC to another one, having done that the PV info is ok but the boot history still lists the history for both the IOCs where the PV is currently assigned (that's right) and also the one where the PV was previously installed. I don't think this is correct ? - The pv-crawler does not detect if one PV is used in several IOCs. Although I could have a small SQL script detecting these mistakes, is there an other way to avoid that ? - Did someone wrote a crawler for EDM clients (not MEDM). I suspect (not having yet watch at this point) that it should be different from the adl crawler from the Irmis package ? Eric Lecorche begin:vcard fn;quoted-printable:Eric L=C3=A9corch=C3=A9 n;quoted-printable:L=C3=A9corch=C3=A9;Eric org:Ganil;Groupe Informatique Machine adr:;;BP 55027;Caen;;14076;France email;internet:[email protected] title:DBA / resp. GMAO / CC Ganil tel;work:02 31 45 47 35 tel;fax:02 31 45 47 28 url:http://www.ganil.fr version:2.1 end:vcard
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
