1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: GOOD Naming conventions for devices and Epics records
To: "Emmanuel Mayssat" <[email protected]>
Cc: "tech talk" <[email protected]>
Date: Fri, 17 Nov 2006 10:54:27 -0800
Ok, I'll bite too...
For small projects with few people and few subsystems the naming convention thing is mostly an ongoing annoyance - it's pretty easy to go change things or just make exceptions or simply leave the resulting chaos in place.
All large projects (at least the recent ones) start with fabulous intentions. The names are constructed to be immediately recognizable by all involved. Simple regular expressions can parse everything. Then the left-handed reverse frambus on the third beam-line spur appears, or some (necessary) secondary support PVs are needed for something, which overloads the original naming convention at some level, or something else unforseen (and unforseeable) happens.
[This reminds me of the management request: "I need a list of specific unknown problems we will encounter!"]
Aliasing can provide some user-level protection from the underlying names. Many subsystems or middleware implementations provide this. When developers need to step into the quagmire to find some interesting problem, they nontheless still need to understand the whole mess.
Sometimes an institute has a hero(ine) who will keep raking through the pile and removing the rotten bits. A benevolent dictator approach works for a while, until the deadline pressures outweigh even his barking.
So a GOOD naming convention starts like Newt Gingrich's congress, with great intentions and high ideals. Some of that survives the rough and tumble of getting a machine going. Ultimately the structure needs fixing or all simply hang their heads and stumble forward.
With a system like IRMIS, which, when it is set up correctly, shows all PVs on all IOCs, as well as all config files and displays in which they are used, one has a chance of keeping track of things. Exceptions to the general GOOD naming convention can be kept up-to-date (by hand, mostly) in an ancillary spreadsheet. One even may have enough information to know everything that needs renaming to fix the exceptions.
Sorry for the mix of metaphors. I really don't see how to do this perfectly, but we will keep learning from each other.
Ron Chestnut
-----Original Message-----
Sent: Friday, November 17, 2006 10:31 AM
To: Gurd, Pamela A.
Cc: Andrew Johnson; tech talk
Subject: GOOD Naming conventions for devices and Epics records
I think what is important in this thread is not what naming convention is being used at site X, but rather what makes a GOOD naming convention.
Here is what I learned from naming conventions with epics.
1/ I like to know which hardware part is providing the signal.
This provides a tremendous help for low level debugging.
(ex. Signals is from pin 2 on ADC 3 on computer X [located at Y])
2/ End user cares about the meaning of the signal.
(ex. Temperature of gun, setting of 3rd magnet in transport line)
3/ PV names are often found hardcoded in programs
4/ Low level and high level programming is managed by 2 different groups.
Solution:
Use several (two) naming conventions!
One for each level and use ALIASING!!!!!
Q: What happens if you change hardware?
You change the low level PV names and the inputs of aliases.
No need to change programs, striptools configuration files, etc.
Enjoy!
Emmanuel Mayssat
Lyncean Technologies, Inc
On Fri, 2006-11-17 at 12:33 -0500, Gurd, Pamela A. wrote:
> It's true that we have had problems with the sequencer going over 28
> characters, but I think they're less of a problem than it would be to
> try to stay within 28 characters.
GOOD Naming conventions for devices and Epics records Emmanuel Mayssat
Prev: RE: GOOD Naming conventions for devices and Epics records Gurd, Pamela A.
Next: Re: Naming conventions for devices and Epics records Elder Matias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Naming conventions for devices and Epics records Pete Jemian
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
