On Mon, 2006-11-20 at 16:28 +0100, Dirk Kraemer wrote:
> Eric Norum schrieb:
> > On Nov 20, 2006, at 5:50 AM, Dirk Kraemer wrote:
> >> Hello all,
> >> I have a problem with EDM. If I start EDM ,then
> >> I see for a moment the message "loading fonts" and a moment later
> >> I get the message "segmentations fault".
> >> I am running EDM on :
> >> - Fedora 5 - gcc 4.1.0-3.i386
> >> - Epics 3.14.8.2
> >> - openMotif 2.3.0-0.1.9.i386
> >> - edm 1-11-0s
> >> I hope that someone can help me. It's the first time that I get this
> >> fault.
> >> Regards
> >> Dirk Kraemer
> > Sounds suspiciously like the problem I encountered on OS X. Here's a
> > copy of the letter I sent to Jeff about this. Perhaps you're seeing
> > the same sort of condition, but with some other pair of static
> > constructors.
> > I downloaded and built the latest version of edm with the current
> > R3.14.2 CVS branch of EPICS. Things build fine, but the executable
> > suffers an access fault when run. I tracked the problem down to a
> > race condition in the C++ static constructors. Code in
> > EPICS_PV_Factory is invoking a guard class mutex that has yet to be
> > set up.
> > Program received signal EXC_BAD_ACCESS, Could not access memory.
> > Reason: KERN_PROTECTION_FAILURE at address: 0x00000008
> > 0x0008ae23 in epicsMutex::lock ()
> > (gdb) where
> > #0 0x0008ae23 in epicsMutex::lock ()
> > #1 0x00088e3a in ipAddrToAsciiEngine::allocate ()
> > #2 0x004aff0b in cac::cac ()
> > #3 0x004cfb5b in ca_client_context::ca_client_context ()
> > #4 0x004b25f4 in ca_context_create ()
> > #5 0x0041f4df in EPICS_PV_Factory::EPICS_PV_Factory ()
> > #6 0x0044cb2b in __static_initialization_and_destruction_0 ()
> > #7 0x8fe0fcb2 in
> > __dyld__ZN16ImageLoaderMachO16doInitializationERKN11ImageLoader11LinkContextE
> > #8 0x8fe0a1c6 in
> > __dyld__ZN11ImageLoader23recursiveInitializationERKNS_11LinkContextE ()
> > #9 0x8fe0a164 in
> > #10 0x8fe0a164 in
> > #11 0x8fe0c646 in
> > __dyld__ZN11ImageLoader15runInitializersERKNS_11LinkContextE ()
> > #12 0x8fe03070 in __dyld__ZN4dyld24initializeMainExecutableEv ()
> > #13 0x0000245a in _start ()
> > #14 0x000023c5 in start ()
> > The offending code in misc/ipAddrToAsciiAsynchronous.cpp is:
> > // for now its probably sufficent to allocate one
> > // DNS transaction thread for all codes sharing
> > // the same process that need DNS services but we
> > // leave our options open for the future
> > ipAddrToAsciiEngine & ipAddrToAsciiEngine::allocate ()
> > epicsGuard < epicsMutex > guard (
> > ipAddrToAsciiEnginePrivate::globalMutex );
> > if ( ! ipAddrToAsciiEnginePrivate::pEngine ) {
> > ipAddrToAsciiEnginePrivate::pEngine = new
> > ipAddrToAsciiEnginePrivate ();
> > ipAddrToAsciiEnginePrivate::numberOfReferences++;
> > return * ipAddrToAsciiEnginePrivate::pEngine;
> > As a quick fix I just link libCom before the EDM libraries as well as
> > after:
> > diff -ur /home/phoebus/NORUME/Desktop/edm/edmMain/Makefile
> > src/EPICS/extensions/src/edm/edmMain/Makefile
> > --- /home/phoebus/NORUME/Desktop/edm/edmMain/Makefile 2006-03-06
> > 13:25:32.0000
> > 00000 -0600
> > /home/phoebus/NORUME/src/EPICS/extensions/src/edm/edmMain/Makefile
> > 2006-11-
> > 14 13:12:30.000000000 -0600
> > @@ -10,7 +10,7 @@
> > edm_LIBS_Linux += 114135a4-6f6c-11d3-95bc-00104b8742df
> > edm_SYS_LIBS_Linux += Xm Xmu Xt Xp Xtst X11 pthread dl
> > - edm_LIBS_Darwin += EdmBase cfcaa62e-8199-11d3-a77f-00104b8742df
> > + edm_LIBS_Darwin += Com EdmBase cfcaa62e-8199-11d3-a77f-00104b8742df
> > edm_LIBS_Darwin += 114135a4-6f6c-11d3-95bc-00104b8742df
> > edm_SYS_LIBS_Darwin += Xm Xmu Xt Xp Xtst X11 pthread dl
> > I've sent mail to Jeff to see if he has a better fix, but for now I
> > can at least work with EDM.
> > --Eric Norum <[email protected]>
> > Advanced Photon Source
> > Argonne National Laboratory
> > (630) 252-4793
> Hi
> I have tried it with your changes, but the result is the same.
> GNU gdb Red Hat Linux (6.3.0.0-1.122rh)
> Copyright 2004 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show warranty" for details.
> This GDB was configured as "i386-redhat-linux-gnu"...Using host
> libthread_db library "/lib/libthread_db.so.1".
> (gdb) run
> Starting program: /home/Dirk/extensions/bin/linux-x86/edm
> Reading symbols from shared object read from target memory...done.
> Loaded system supplied DSO at 0x41cfd000
> [Thread debugging using libthread_db enabled]
> [New Thread -1208293152 (LWP 7736)]
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread -1208293152 (LWP 7736)]
> 0x00000000 in ?? ()
> (gdb)
Make sure that you are not having a problem with fonts.
Sheng Peng recently had run-time core dumps due to some font issue.
Hopefully, Sheng will reply to this thread.
I and not having any problems and have the following setup:
OS: Fedora Core release 5 (Bordeaux)
KERNEL: Linux bengal 2.6.18-1.2200.fc5
Compiler: gcc version 4.1.1 20060525 (Red Hat 4.1.1-1)
MOTIF: openmotif-2.3.0-0.1.9.3
EPICS_BASE: R3.14.8.2
EDM: edm 1-11-0s
Ernest
> regards Dirk
- Segment fault for edm 1-11-0s Dirk Kraemer
- Re: Segment fault for edm 1-11-0s Eric Norum
- Re: Segment fault for edm 1-11-0s Dirk Kraemer
Re: Error while cross-compiling EPICS for arm Andrew Johnson
Re: Segment fault for edm 1-11-0s John William Sinclair
<2006>
2025
Incorrect display of Y label of X-Y Graph in edm Jianguo DING
<2006>
2025
