1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Building and testing Libera EPICS
To: tech talk <[email protected]>
Date: Tue, 21 Nov 2006 10:33:58 -0500
Yan Yingbing wrote:
I am sure the EPICS libraries are on my path. I have set the environment
variables LD_LIBRARY_PATH and PATH from the very start.
        export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$EPICS_BASE/lib"
        export PATH="$PATH:$EPICS_BASE/bin"
I would normally expect to see an architecture part to your library and command paths. So assuming the EPICS_HOST_ARCH environment variable is set, "$EPICS_BASE/lib" would instead be "$EPICS_BASE/lib/$EPICS_HOST_ARCH" and "$EPICS_BASE/bin" would instead be "$EPICS_BASE/bin/$EPICS_HOST_ARCH".
-lewis
The error message is the same:
../../bin/linux-arm/myexample: relocation
error: ../../bin/linux-arm/myexample: undefined symbol:
pvar_func_asSub
RE: Building and testing Libera EPICS éæç
Prev: Re: Segment fault for edm 1-11-0s Dirk Kraemer
Next: Re: Building and testing Libera EPICS Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Building and testing Libera EPICS éæç
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
