I have installed edm-1-11-0s on Fedora Core 4 and SUSE 9.0 (EPICS base-3.14.7). On Fedora Core 4 I had to remove the lines in "fonts.list", which were marked by Dirk Kraemer in his e-mail from 21.11.2006 to avoid a "Segmentation Fault" during startup of the program. Now edm starts without error but on both operating systems there are no edm-components loaded from libPV.so. The command "$EDM -add $EDMBASE/pvFactory/O.$ODIR/libPV.so" in "setup.sh" produces the message: "Library contains no edm components". What might be the reason? The output during installation of the library is attached: "Inst_pvFactory" I`m especially interested in the edm object "Byte". Thanks for any help Dorothea Wehler make -C pvFactory install make[1]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory' perl /home/LLRF/EPICS/base-3.14.7/configure/tools/makeMakefile.pl O.linux-x86 ../../../.. perl /home/LLRF/EPICS/base-3.14.7/configure/tools/makeMakefile.pl O.linux-386 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[2]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-x86' make[2]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-x86' make[2]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-x86' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../textupdate.cc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../SciPlot.c ../SciPlot.c: In function ¡ÆDrawAll¡Ç: ../SciPlot.c:3286: warning: ¡Æy1¡Ç may be used uninitialized in this function ../SciPlot.c:3286: warning: ¡Æx1¡Ç may be used uninitialized in this function ../SciPlot.c:3415: warning: ¡Æx1¡Ç may be used uninitialized in this function ../SciPlot.c:3415: warning: ¡Æy1¡Ç may be used uninitialized in this function /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../strip_data.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../strip.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../regTextupdate.cc ../textupdate.h:28: warning: ¡Ævoid drag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:30: warning: ¡Ævoid selectDrag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:32: warning: ¡Ævoid selectActions(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:34: warning: ¡Ævoid pvInfo(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../byte.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../pv_register.cc ../textupdate.h:28: warning: ¡Ævoid drag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:30: warning: ¡Ævoid selectDrag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:32: warning: ¡Ævoid selectActions(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:34: warning: ¡Ævoid pvInfo(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined /usr/bin/ar -rc libPV.a textupdate.o SciPlot.o strip_data.o strip.o regTextupdate.o byte.o pv_register.o /usr/bin/ranlib libPV.a Installing library ../../../../lib/linux-x86/libPV.a /usr/bin/ranlib ../../../../lib/linux-x86/libPV.a /usr/bin/g++ -o libPV.so -shared -fPIC -L../../../../lib/linux-x86 -Wl,-rpath,/home/LLRF/EPICS/extensions/lib/linux-x86 -Wl,-rpath,/home/LLRF/EPICS/base-3.14.7/lib/linux-x86 textupdate.o SciPlot.o strip_data.o strip.o regTextupdate.o byte.o pv_register.o -lpthread -lreadline -lcurses -lm -lrt Installing shared library ../../../../lib/linux-x86/libPV.so make[2]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-x86' make -C O.linux-386 -f ../Makefile TOP=../../../.. T_A=linux-386 install make[2]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-386' make[2]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-386' make[2]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-386' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -march=i386 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../textupdate.cc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -march=i386 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../SciPlot.c ../SciPlot.c: In function ¡ÆDrawAll¡Ç: ../SciPlot.c:3286: warning: ¡Æy1¡Ç may be used uninitialized in this function ../SciPlot.c:3286: warning: ¡Æx1¡Ç may be used uninitialized in this function ../SciPlot.c:3415: warning: ¡Æx1¡Ç may be used uninitialized in this function ../SciPlot.c:3415: warning: ¡Æy1¡Ç may be used uninitialized in this function /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -march=i386 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../strip_data.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -march=i386 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../strip.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -march=i386 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../regTextupdate.cc ../textupdate.h:28: warning: ¡Ævoid drag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:30: warning: ¡Ævoid selectDrag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:32: warning: ¡Ævoid selectActions(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:34: warning: ¡Ævoid pvInfo(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -march=i386 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../byte.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -march=i386 -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib ../pv_register.cc ../textupdate.h:28: warning: ¡Ævoid drag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:30: warning: ¡Ævoid selectDrag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:32: warning: ¡Ævoid selectActions(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined ../textupdate.h:34: warning: ¡Ævoid pvInfo(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined /usr/bin/ar -rc libPV.a textupdate.o SciPlot.o strip_data.o strip.o regTextupdate.o byte.o pv_register.o /usr/bin/ranlib libPV.a Installing library ../../../../lib/linux-386/libPV.a /usr/bin/ranlib ../../../../lib/linux-386/libPV.a /usr/bin/g++ -o libPV.so -shared -fPIC -L../../../../lib/linux-386 -Wl,-rpath,/home/LLRF/EPICS/extensions/lib/linux-386 -Wl,-rpath,/home/LLRF/EPICS/base-3.14.7/lib/linux-386 textupdate.o SciPlot.o strip_data.o strip.o regTextupdate.o byte.o pv_register.o -lpthread -lreadline -lcurses -lm -lrt Installing shared library ../../../../lib/linux-386/libPV.so make[2]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-386' make[1]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory'
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
