1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: wxPython timer and KEK CaPython314 cause core dump
To: Noboru Yamamoto <[email protected]>
Cc: [email protected]
Date: Wed, 6 Dec 2006 12:52:29 -0600 (CST)
Dear Noboru,
Thank you.  I must say the KEK CaPython314 is very easy to use.
I am not surprised that your little test below won't crash,
since it does not contain a wx.Timer.  In order to repeat my
crash, a wx.Timer must be constructed, it must be bound to a
onTimer function, and it must be started.  Using
threading.Timer instead of wx.Timer will not cause the crash.
 I cannot tell who is guilty, wx.Timer or CaPython314.  I also
have the feeling that Python 2.5 may be the problem.
Zhong
---- Original message ----
>Date: Wed, 06 Dec 2006 10:47:29 +0900
>From: Noboru Yamamoto <[email protected]>
>To: [email protected]
>Hi,
>I'm not familiar with WxPytho (yet).
>But, the following code works on MacBook running MacOSX
10.4.8 with
>Python2.5,
wxPython2.7-osx-unicode-2.7.2.0-universal10.4-py2.5.dmg
>and KEK version of CaPython314 ( I should have used the
different name
>to avoid confusion with FNAL version. Sorry).
>import wx,ca
>class MyApp(wx.PySimpleApp):
>    def OnInit(self):
>        frame = wx.Frame(None, -1, "Hello from wxPython")
>        frame.Show(True)
>        self.frame=frame
>        self.ch=ca.channel("fred")
>        self.ch.wait_conn()
>        self.ch.monitor(self.ca_callback)
>        self.ch.flush()
>        self.SetTopWindow(frame)
>        return True
>    def ca_callback(self,valstat):
>        self.ch.update_val(valstat)
>        self.frame.Title="%s:%f"%(self.ch.name,self.ch.val)
>if __name__ == "__main__":
>    app = MyApp(0)
>    app.MainLoop()
>I hope this can give some idea.
>Regards,
>Noboru Yamamoto
>EPICS group/J-PARC control group
>KEK, JAPAN
>Zhong Ren wrote:
>> I managed to isolate a core dump in a minimized Python code
>> (see below).  I found two components are essential to cause a
>> core dump: wx.Timer and ca.Monitor (or ca.Get).  Can someone
>> tell what the problem is?
>> import wx
>> import ca
>> def onTimer(event): pass
>> ca.Monitor('S:SRcurrentAI')
>> appli = wx.PySimpleApp()
>> frame = wx.Frame(None)
>> timer = wx.Timer()
>> timer.Bind(wx.EVT_TIMER, onTimer)
>> timer.Start(milliseconds = 10, oneShot = False)
>> appli.MainLoop()
>> Other info:
>> Pyhton 2.5
>> wxPython 2.6.3.3
>> RedHat Linux x86_64
>> GCC 4.1.1
>> To test, let the routine run for a while.  A core dump will
>> occur in a few minutes.
>________________
Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Prev: RE: JCA, Gateways and EPICS_CA_ADDR_LIST Rees, NP (Nick)
Next: RE: Problems with Channel Access calls on an IOC moving from R3.13.7 -> 3.14.8 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: wxPython timer and KEK CaPython314 cause core dump Matt Newville
Next: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
