Looks like an infinite loop. DZ:WIDTH processes DZ:TRANS, which then process DZ:WIDTH again via the OUTC field. This is the case for the other ao's, too. There is a slits database in the synApps package that should do what you need, or you could use it as a starting point and modify it as needed. Kurt Goetze APS Beamline Controls Dirk Zimoch wrote: Hi Tim,
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
