1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: [Fwd: EPICS Base @ HP-UX: Volunteers wanted]
To: EPICS tech-talk <[email protected]>
Date: Tue, 12 Dec 2006 15:01:41 -0600
In order that Ralph's Call For Volunteers receives as wide an audience as possible, I'm forwarding this message to tech-talk (apologies to the core-talk folks who've already seen it once). If your site expects to need to run EPICS R3.14.9 on HP-UX, you should have someone step up now or we may have to drop HP-UX from the list of architectures officially supported by EPICS.
- Andrew
-------- Original Message --------
Subject: EPICS Base @ HP-UX: Volunteers wanted
Date: Tue, 12 Dec 2006 15:27:06 +0100
Organization: BESSY
To: EPICS Core Talk <[email protected]>
Hello everyone,
trying to resolve the situation with an outdated C++ compiler crashing
on the EPICS sources, I found out that BESSY doesn't seem to be able to
support testing Base on HP-UX any longer.
We are in the middle of converting to Linux, the software on our few
remaining HP-UX machines has been in frozen state for a while, so asking
for an update of a compiler to test a software that is not going to be
used on that platform
... sounds a lot like asking someone to waste time to be able to waste
more time.
I know we intended to keep HP-UX supported for 3.14 and I know there are
others still using HP machines, so I'm not feeling too happy with this
issue. In any case I would like to keep the HP-UX configuration files
around for a little longer.
Well, I'm throwing the ball high up in the air and start running ....
maybe one of the KEK colleagues (the only remaining HP users as far as I
know) is able to catch it?!
I'm definitely willing to continue helping with ideas and suggestions,
if someone takes over. No question. But without a current system and
compiler I'm not able to compile nor test.
Sorry -
Ralph
-- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Kazuro FURUKAWA
Prev: caDDE source code? Geoff Savage
Next: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Kazuro FURUKAWA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
