Hello:
Thanks to Eric Norum and Miroslaw Dach,
the Matlab ChannelAccess client 'mca'
now also works with Octave:
Since octave is a little bit cheaper than
Matlab, that might be interesting.
On the other hand, Matlab has nicer Java
integration, so you can actually directly
use JCA/CAJ and no longer need mca...
And then there's Scilab. Too many choices!
If you're still interested in this [m|o]ca update,
you can get it by following the links
from the APS EPICS web page:
Extensions, Clients, MCA, ...
Well, except from right about now until Monday,
when power outages at the SNS will cause the
final web page to be inaccessible.
-Kay
Re: Problems with database breakpoint routines. Andrew Johnson
USB interface with EPICS Kevin M. Peterson
<2006>
2025
Parker motor controllers Coles Sibley III
<2006>
2025
