(Preface: new to using Tcl so please don't assume I know what I'm doing) I have built et_wish from the distribution http://www.aps.anl.gov/epics/download/extensions/caTCL_20020802.tar.gz I can start et_wish and the various Channel Access commands work fine from the et_wish command line, but when I try to use them from inside a proc they stop working. If inside a proc I use pv link variable_name record_name pv put variable_name then the value of the record remains unchanged. See example code below.
2) I see that oagwish from APS appears more actively maintained. Should I be using this instead? Thanks John Dobbins This et_wish command line code works: % pv link cur bl_mag_crv1_cmd 0 % set cur 0.001 0.001 % pv put cur 0 This script does not: proc my_test {} { pv linkw cur bl_mag_crv1_cmd set x [pv info cur state] puts $x set cur 0.001 puts "cur = $cur" pv put cur after 50 set x [pv info cur state] puts $x puts "executed test" } my_test and has output: {cur OK} cur = 0.001 {cur OK} executed test
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
