The arbitary function generator VME-4145 we are using is discontinued and the replacement is not available now. We could buy some if you have more spare parts or have some parts lying around. Basically, the requirements for the arbitary function generator is as follows: > 33 millisecond long programmable waveform triggered at 30 Hz > bipolar output > 10 usec time resolution (or better) (implies a memory length of > 3.3K) > 1% amplitude resolution (or better) (e.g. 10-12 bits would be fine) It would also be great if you could recommand some modules with EPICS device driver which can meet the above requirements. Any answers and suggestions would be greatly appreciated. Shifu Xu
| ANJ, 10 Nov 2011 |
· Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
