1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Switchable Links
To: Robert Emery <[email protected]>
Cc: [email protected]
Date: Tue, 23 Jan 2007 11:47:31 -0600
Hi Robert,
Robert Emery wrote:
Is it possible to modify links at run time?
I have heard the term re-targetable link mentioned
but am not sure how to implement it.
It has been possible to change soft links (i.e DB or CA links) at runtime for several years - just modify the INP/OUT/INPA etc. field using your preferred mechanism (via CA, using a dbpf command from the console, or even by doing a put from a stringout record).
Since R3.14.8 it has also been possible to change hardware addresses at runtime, but only if the device support you are using has special code to handle this. There are no real-world device support layers that I'm aware of which can do this yet, but the code is available in base to allow you to if you need it. If you need more information see section 12.5 in the Application Developer's Guide for R3.14.8.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Switchable Links Robert Emery
Prev: Switchable Links Robert Emery
Next: LivEPICS Fedora Core 5 Release v.1.0 Mauro Giacchini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
