1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM Byte Monitor Object
To: Paul Sichta <[email protected]>
Cc: [email protected]
Date: Wed, 24 Jan 2007 16:52:32 -0600
Paul Sichta wrote:
MEDM 3.1.1 supports the Byte Monitor Object in the UP and the RIGHT
directions, version 3.0.3 supports it in the DOWN and RIGHT directions
My copy of MEDM 3.1.1 supports "down" and "right", and gives a warning if I set the widget to either "up" or "left".
(medmByte.c).  In 3.0.3 edit mode, you can choose any of the four directions;
at runtime the invalid direction is overridden with the supported one.  The
current MEDM Manual's 'direction attribute' table says the Byte Object can
use all four directions, although the paragraph for the Byte Monitor
describes the direction limitations.
So a display created under 3.0.3 with a medmByte in the UP direction will
generate a warning (in stdout and MEDM Message Window) under 3.1.1 . The
appearance/vertical-alignment of the 'bits' are the same for both medm's, so
it's not too disasterous.
From a glance at the source code changes between the releases and after some investigation, all that may have changed since 3.0.3 is the nomenclature used for the directions, to make the widget's behaviour match the actual wording the user selects.
In 3.1.1 the bit adjacent to the Start Bit is always displayed either below or to the right of the start bit. However that adjacent bit number can be higher or lower than the Start Bit depending on whether the End Bit setting is larger or smaller than the Start Bit setting.
My conclusion: This change was a bug fix, not a regression, and should not affect the functionality of any existing displays.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
RE: MEDM Byte Monitor Object Paul Sichta
Prev: MEDM Byte Monitor Object Paul Sichta
Next: RE: MEDM Byte Monitor Object Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
