1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Setting an IOC clock from the vxWorks shell
To: EPICS Tech Talk <[email protected]>
Date: Wed, 28 Feb 2007 11:48:08 +0100
Just for completeness:
It is intended to include timestamp synchronisation into the next release of EPICS base - things were just coming into place too late for 3.14.9.
It will most probably be based on generalTime and the work done at the SLS (Timo et al.). Integration and tests are still to be done.
Cheers,
Ralph
Thompson, David H. wrote:
Timo, Sheng Peng, and I have been collaborating on a package that loads onto an IOC that may help you. It replaces the NTP client in iocClock with a system that provides for multiple time providers on an IOC, one of which is the vxWorks clock. The vxWorks clock is set periodically when NTP or a better time provider is available. It supports hardware timing systems as well. One of the things it does is fall back to internal timekeeping if the NTP server fails, all transparently.
You can get it at http://ics-web1.sns.ornl.gov/share/generalTime.tar.gz.
There were presentations on it at the APS and SLAC EPICS meetings.
RE: Setting an IOC clock from the vxWorks shell Thompson, David H.
Prev: RE: Setting an IOC clock from the vxWorks shell Thompson, David H.
Next: task priorities, busy cpu, and timeout Dennis Nicklaus
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
