1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Serial port access and loging services for IOCs?
To: [email protected]
Date: Fri, 02 Mar 2007 12:17:19 -0500
At Jlab, we've got (50-60% so far of) our IOC serial ports connected to Cyclades Corporation T-series Terminal servers (http://www.avocent.com/web/en.nsf/Content/Cyclades-TS). These terminal servers are available in 1, 4, 8, 16, and 32 port flavors, run an embedded linux. As I recall, these costed about $100/port at the 16 or 32 port size, and more/port at the smaller configurations.
These are simple, little appliances requiring minimal configuration. You basically just have to provide it with network settings, connect the incoming serial lines from the iocs and edit a config file named portslave.conf.
Some nice features:
- They will buffer the serial console output which can be stored locally (in flash RAM, not much space), written to an NFS mounted filesystem (one logfile/serial port), or sent via syslogs to a loghost.
- The serial port may be accessed in r/w mode by one user and simultaneously in read-only mode by others.
- Users can be required to authenticate on a per-port basis against a local password or externally (in our case via a radius server)
- We have configured it so that users can ssh directly to the serial port and need not first telnet to the terminal server. - We turn it off, but you can also enable the built in web server on the console server and allow users to connect to the logs/terminals via a web browser.
I'd be happy to follow-up with more information if requested.
-Theo
RE: Serial port access and loging services for IOCs? Thompson, David H.
Prev: Re: epics / fpga David Kline
Next: Re: epics / fpga D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Serial port access and loging services for IOCs? Ralph Lange
Next: RE: Serial port access and loging services for IOCs? Thompson, David H.
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
