1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Daylight savings time
To: "Thompson, David H." <[email protected]>
Cc: [email protected]
Date: Mon, 12 Mar 2007 17:34:11 -0500
Thompson, David H. wrote:
Something very weird just happened here and we are still trying to figure out why.
Are you guys running the standard R3.14.x version of base/src/libCom/osi/os/vxWorks/iocClock.c or does General Time just register itself as a time provider using iocClockRegister()? If the latter then the code it's running is all yours...
Running iocs were updated by just setting the TIMEZONE environment variable and all is fine.
Iocs that were rebooted today had the TIMEZONE variable set in a common startup script that is called before everything else. Those IOCS seemed to display the correct time but camonitor was reporting the time an hour earlier. The hardware timing module displayed the time an hour later than it was. The timing system was not rebooted and had the correct time on the hardware link.
We fixed the problem by moving the TIMEZONE setting to the post-startup script.
Has anyone else had similar problems?
We had R3.14 IOCs with both the correct and the old settings for EPICS_TIMEZONE, and both behaved as I expected them to, but we're not using a timing system with these, they're just soft timing slaves. The vxWorks version of the iocClockInit() routine that runs at iocInit() looks to see if the TIMEZONE variable is set and if so it uses that, but if not it copies the setting of EPICS_TIMEZONE to the TIMEZONE environment variable. After iocInit() EPICS_TIMEZONE will be ignored, and any adjustments at runtime have to be made directly to TIMEZONE.
If you set TIMEZONE before iocInit(), does it still have the same value afterwards or is it being overwritten somehow? Is General Time or your hardware event receiver driver making any use of local time? It probably shouldn't be.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
RE: Daylight savings time Thompson, David H.
Prev: RE: Daylight savings time Laznovsky, Michael
Next: Re: Daylight savings time Lawrence T. Hoff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Daylight savings time Thompson, David H.
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
