1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Daylight savings time
To: "Lawrence T. Hoff" <[email protected]>
Cc: "Thompson, David H." <[email protected]>, [email protected]
Date: Tue, 13 Mar 2007 10:01:56 -0500
Lawrence T. Hoff wrote:
FWIW - in VxWorks it is possibly to crate a task with a private copy of environment variables. In such a case it would be fruitless to change the "global" TIMEZONE variable and hope that it would affect the already-running task - same as UNIX processes.
True, although that should not occur for tasks created using the libCom OSI routine epicsThreadCreate(), which passes the VX_FP_TASK option but not VX_PRIVATE_ENV that would turns on private environment support. I guess the main culprits for this might be vendor-supplied binary drivers that call taskSpawn() or that might use envPrivateCreate().
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Re: Daylight savings time Eric Norum
Daylight savings time Thompson, David H.
Re: Daylight savings time Lawrence T. Hoff
Prev: Re: Darwin and EPICS_CA_AUTO_ADDR_LIST issue Burkhard Kolb
Next: Re: Daylight savings time Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Daylight savings time Lawrence T. Hoff
