1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with compiling Channel Archiver
To: "Kay-Uwe Kasemir" <[email protected]>
Cc: <[email protected]>
Date: Fri, 16 Mar 2007 10:01:24 -0500
>>> Kay-Uwe Kasemir <[email protected]> 3/16/2007 9:44 AM >>>
On Mar 16, 2007, at 10:25 , David Dudley wrote:
> Adding the 'class' keyword to line 130 of the 'LibIO/DataFile.h'
> file did fix that problem.
OK.
> Now, I have an error (much farther down in compiling) that says:
The good news is that you're about as far down with compiling as
you'll get.
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -
D_REENTRANT -ansi  -g  -Wall     -D ARCH_VERSION=2 -D ARCH_RELEASE=9 -
D ARCH_PATCH=2 -D ARCH_VERSION_TXT=\"2.9.2\" -I/home/daviddu/include -
I/usr/local/EPICS/base/include -I/usr/local/EPICS/base/include/os/
Linux -I/usr/local/xerces-c-src2_4_0/include -I${prefix}/
include       -g  -I. -I.. -I/usr/local/EPICS/include/os/Linux -I/usr/
local/EPICS/include -I/usr/local/EPICS/base/include/os/Linux -I/usr/
local/EPICS/base/include -I/usr/local/EPICS/include/os/Linux -I/usr/
local/EPICS/include        ../main_standalone.cpp
> ../main_standalone.cpp:13:26: error: xmlrpc_abyss.h: No such file
> or directory
Following the admittedly lengthy stuff in the manual's Setup/
Installation section,
I end up with /usr/local/include/xmlrpc_abyss.h.
Do you have that?
In addition, the program "xmlrpc-c-config" should be on the PATH.
Is it?
With that,
   ChannelArchiver/XMLRPCServer/xmlrpc-config-wrapper server-flags
should produce something like "-I/usr/local/include".
Does it?
Or does that result in the "-I${prefix}/include" which probably
won't work?
-Kay
OK, missed something in the manual, I guess.  Under Gentoo, I have
installed:
dev-java/xmlrpc = version 1.2_beta-r1
dev-libs/xmlrpc-c = version 1.06.03
In /usr/include, I have:
find . -name 'xmlrpc*'
./xmlrpc_server.h
./xmlrpc_server_abyss.h
./xmlrpc_cgi.h
./xmlrpc_client.h
./xmlrpc_server_w32httpsys.h
./xmlrpc-c
./xmlrpc.h
I have xmlrpc_server_abyss.h, but not a xmlrpc_abyss.h.
I do have xmlrpc-c-config in my path, but when I do the
'XMLRPCServer/xmlrpc-config-wrapper server-flags' command, I get
'-I$(prefix)/include' as a result.
Did I miss installing something?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Prev: Re: Problem with compiling Channel Archiver Kay-Uwe Kasemir
Next: Re: Problem with compiling Channel Archiver Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
