Hi Dayle,
Dayle Kotturi wrote:
I am using SNL to manage the operational mode of a phase and amplitude ctrllr.
Mode is either CALIBRATING or RUNNING.
When RUNNING, I attempt to disallow changes to gain setting via entry{}
clause of state RUNNING where I set DISA to 1 for the gain PV.
I can see DISA field is set correctly to 1 via dbpr.
On the EDM GUI, however, I am still able to change the gain.
The gain is a longout record.
From the doc, I understand that when DISA==DISV==1, processing should
not occur. Why does it?
Are you sure that your gain is actually being sent out to the hardware
when DISA==DISV? What disabling the record means is that the record's
process routine will not run, thus no device support output or alarm
checking, DRVH/DRVL clipping etc. However this does not stop CA from
being able to write to the record's modifiable fields, nor any CA
monitors from seeing those updated field values (since a ca_put
automatically causes a monitor event on the field that is changed).
HTH,
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
- vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
- What's wrong if a PV with DISA=1 still processes? Dayle Kotturi
Re: String In and Output records Ned D. Arnold
Re: What's wrong if a PV with DISA=1 still processes? Ned D. Arnold
<2007>
2025
<2007>
2025
