1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: drvTS
To: "Denison, PN \(Peter\)" <[email protected]>
Cc: [email protected], Kalantari Babak <[email protected]>
Date: Wed, 28 Mar 2007 09:19:24 +0200
Hello Peter,
Denison, PN (Peter) wrote:
I was searching for drvTS yesterday, and couldn't find it for versions
of base after 3.14.8
I know that it was removed from base, and I found this section of the
release notes:
"These are removed from EPICS base. The version that previously came
with base was the version that worked with the APS event system. It is
available from APS. The version that works with the newer event systems
that evolved from the APS system is available from the Swiss Light
Source."
As we are using the "newer event systems", I guess we'll need the SLS
version. Can anyone help me get hold of it - Timo?
If you _really_ want it, we can give you 'our' version of drvTS. However,
if you are using 3.14., I would recommend moving to GeneralTime. We have
a GeneralTime time driver for the MicroResearch EVR/EVG( although it may
need some minor modifications for the 200-series EVRs.).
We have no intentions to support drvTS further. GeneralTime is a big improvement
over drvTS.
I assume that this is orthogonal to generalTime, and I'll still need a
version of drvTS to support the MicroResearch EVR, even if I were to get
hold of generalTime (which I have managed to find a link for)? We have
the drivers for the EVR, but they don't compile against base-3.14.8
because drvTS is missing.
I would like to state it once again:
the drvTS will not be supported anymore and will be replaced by General Time.
(as discussed in the last EPICS meeting. It took us a while to implement the replacement
but at least a first version exists since a few months.)
There are still a few issues to be sorted out, but we have tested the GeneralTime (event)
driver extensively.
We have sent our GeneralTime package (GT base + our eventTime driver) to Andrew
and a few other people for them to take a look at it and to do the necessary preparations
for integrating it. We can of course send you the same package, and try to help you
to get started. There will also be a talk in the Epics meeting in Hamburg (by Babak)
and Babak will be there for detail discussions.
I do not immediately remember what the dependency between the EVR drivers and drvTS
is, but Babak could probably tell it right away. Let us take a look at it (however, this week there
is a SLS shutdown and people are pretty busy with maintenance and testing new stuff.)
best regards,
Timo
Timo Korhonen PSI (Paul Scherrer Institut, http://www.psi.ch) CH-5232 Villigen PSI tel + 41- 56 3103262 fax + 41 - 56 310 3383 e-mail: [email protected]
RE: drvTS Denison, PN (Peter)
Prev: Re: DISP and permissive record. Debora Kerstiens
Next: RE: drvTS Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: drvTS Denison, PN (Peter)
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
