1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: WireSet & mpc8540
To: Korhonen Timo <[email protected]>
Cc: "'[email protected] '" <[email protected]>
Date: Thu, 29 Mar 2007 06:44:46 -0700
On Thu, 2007-03-29 at 15:12 +0200, Korhonen Timo wrote:
> Hello all,
> I have been trying to get EPICS running on a Motorola mv3100 and vxWorks
> 6.2,
> using the newest EPICS release (3.14.9). The build goes smoothly and
> without complaints.
> However, when I build the application and load it, I get a few
> unresolved symbols:
> ld < mv3100.munch
> Warning: module 0x1a16f20 holds reference to undefined symbol
> _Z7WireSetIfEvRKT.
> _Z7WireSetIiEvRKT.
> _Z7WireSetIsEvRKT.
> ld(): error loading file (errno = 0xe0005).
> value = 0 = 0x0
What object file is referencing this in your App?
I don't see this on my mv3100 application:
> Trying to trace these back, they seem to come from Channel Access. The
> prototypes
> (WireSet, I believe) are declared in osiWireFormat.h, and the
> implementation, as far
> as I have understood it correctly, are in osdWireFormat.h. I could not
> sort out the ifdefs to
> see why this routine is not linked in, or what the problem actually is.
WireSet is new in R3.14.9.
> I ran out of ideas. Can somebody help me further?
Make sure that you build iocCoreLibrary in EPICS BASE.
Make sure that you have the following in your Makefile:
xxx_LIBS += $(EPICS_BASE_IOC_LIBS)
xxx_OBJS_vxWorks += $(EPICS_BASE_BIN)/iocCoreLibrary
-- Ernest
> Timo
WireSet & mpc8540 Korhonen Timo
Prev: RE: ASYN Octet driver question David Dudley
Next: Proposed change in asyn interruptCallback APIs Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: WireSet & mpc8540 Korhonen Timo
Next: RE: WireSet & mpc8540 Jeff Hill
