1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question about mbboDirect record
To: "tech-talk tech-talk" <[email protected]>
Date: Thu, 29 Mar 2007 17:39:34 -0500
Folks,
I have a question about the mbboDirect record, specifically the
interaction of the .VAL and .B0-.BF fields.
On the mbbiDirect record the 	.VAL fields and .BO-.BF fields are
always consistent.
However, this does not seem to be the case with the mbboDirect record.
If I write to the .Bn fields of the mbboDirect record, the .VAL field
updates as expected.  However, the opposite is not true.  If I write to
.VAL field, the .Bn fields do not change.  This does not make sense to
me.
Can someone explain why this is so, or is it a bug?
Re: Question about mbboDirect record Andrew Johnson
Prev: Re: Maximum archival rate Lawrence T. Hoff
Next: RE: WireSet & mpc8540 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: WireSet & mpc8540 Jeff Hill
Next: Re: Question about mbboDirect record Andrew Johnson
