1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Outputting a constant value
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Wed, 04 Apr 2007 10:13:21 -0500
David -
I seem to remember (when I actually worked with this stuff) that setting the DOL to 1 only worked for Soft Channel BOs.  Try setting DOL to a link that is always one (e.g. DISV or DISA of the same BO record) and OMSL to closed_loop.  This way it will always fetch a 1 for the output.  This eliminates the need for the extra BI record you described.
Ned
David Dudley wrote:
Unfortunately, that didn't work.
In vdct, I can set the .VAL field to 1, but when I load the db, the VAL
field is 0.  Setting DOL to 1 causes it to have a 'CONSTANT 1' value
when you do a 'dbpr' on the field, and I have OMSL set to 'closed-loop',
however the .VAL field remains at 0.  If I do a forward link to the
block, it outputs a zero, and the .VAL remains 0.  If a do a 'dbpf' to
set the value to 1, it then works fine.  What I did as a patch around
the questionable action was to use a BI block with its DTYPE set to
'Soft Channel' and an INP of '1' that is linked to the BO, but seems
like a round-about way of doing such a simple thing.
I thought I was probably just missing something on the BO block.
David Dudley
"Paul Sichta" <[email protected]> 4/4/2007 9:20 AM >>>
David,
Can you set the DOL to '1' and use closed-loop control, rather than
the
default supervisory.
BEGIN:VCARD VERSION:2.1 X-GWTYPE:USER FN:David Dudley TEL;WORK:880-3740 ORG:;MIS TEL;PREF;FAX:880-3741 EMAIL;WORK;PREF;NGW:[email protected] N:Dudley;David END:VCARD
RE: Outputting a constant value David Dudley
Prev: RE: Outputting a constant value David Dudley
Next: Re: Outputting a constant value Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
