1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics compiling problem
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Tue, 10 Apr 2007 19:13:57 +0800
I see the configure files, and replace the directory config and configure. at
last, I make it:) really very thankful to your great help. the log of
executing st.sys is as follows:
Welcome to rtems-4.6.0(PowerPC/PowerPC 7455/mvme5500) on MVME5500-0163
Build Date: 20070328EST14:52:34
Now BSP_mem_size = 0x1FE00000
BSP_Configuration.work_space_size = 500000
PCI BASE config register 0x82000000
Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
Universe Master Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0F000000 0x90000000 A32, Dat, Sup
1:    0x00000000 0x00FF0000 0x9F000000 A24, Dat, Sup
2:    0x00000000 0x00010000 0x9FFF0000 A16, Dat, Sup
Universe Slave Ports:
0:    0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr
Overriding main IRQ line PCI info with 12
Registering /dev/console as minor 0 (==/dev/ttyS0)
                                                  Welcome to RTEMS GeSys
This system $Name: SSRL_RTEMS_20040521 $ was built on 20070401EDT22:30:37
$Id: init.c,v 1.23 2004/05/28 18:33:57 till Exp $
Copyright RTEMS-mvme5500 BSP, Shuchen K. Feng, Brookhaven National Laboratory
All rights reserved, including all its functions
Ethernet driver name gt unit 1
Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
(c) 2004, Brookhaven National Lab. <[email protected]> (RTEMS/mvme5500 port)
Read EEPROM address 00:01:af:0b:23:4e
roSoItOpCcA_DiDnMiUtL:T Iu s(iSnIgO CnDeEtLwMoUrLkT Ii)n:t eirsf aicte  a'bgotu
 x or tx ?
Bootpc testing starting
bootpc hw address is 0:1:af:b:23:4e
My ip address is 192.168.20.163
Domain Name Server is 202.38.128.58
Domain Name Server is 202.38.128.10
Ignoring BOOTP/DHCP option code 40
Domain name is ihep.ac.cn
Subnet mask is 255.255.255.0
Server ip address is 192.168.20.162
Gateway ip address is 192.168.20.1
Log server ip address is 192.168.20.162
This is RTEMS-RPCIOD Release $Name: SSRL_RTEMS_20040521 $
($Id: rpcio.c,v 1.34 2004/04/13 07:55:44 till Exp $)
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
This is RTEMS-NFS Release $Name: SSRL_RTEMS_20040521 $
($Id: nfs.c,v 1.32 2004/04/13 07:54:23 till Exp $)
Trying to synchronize NTP...FAILED
Symbol file can be loaded by:
   NFS: [<uid>.<gid>@][<host>]:<export_path>:<symfile_path>
  TFTP: [/TFTP/<host_ip>]<symfile_path>
   RSH: [<host>:]~<user>/<symfile_path>
Enter Symbol File Name: 192.168.20.162:/home/shl/psApp:tftpboot/st.sys
Trying to mount 192.168.20.162:/home/shl/psApp on /boot
Change Dir to '/boot/tftpboot/'
Trying symfile 'BUILTIN', system script 'st.sys'
Type 'cexp.help()' for help (no quotes)
'st.sys':
  ld = cexpModuleLoad
0x0000a6b4 (42676)
  ld("../power_supplyApp/src/O.RTEMS-mvme5500/nihao.o")
0x01f5c760 (32884576)
  ld("../bin/RTEMS-mvme5500/power_supply.boot")
Checking format: File format not recognized
0x00000000 (0)
  ld("../bin/RTEMS-mvme5500/power_supply.obj")
0x01f5c518 (32883992)
  bspExtVerbosity=0
0x00000000 (0)
  nfsInit(0,0)
0x00000000 (0)
  dbLoadDatabase("../dbd/power_supply.dbd")
0x00000000 (0)
  power_supply_registerRecordDeviceDriver(pdbbase)
0x00000000 (0)
  dbLoadRecords("../db/power_supply.db")
0x00000000 (0)
  iocInit()
Starting iocInit
###  EPICS IOC CORE built on Apr 10 2007
###  EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
thanks again! and hope to get more help!
Regards
Haoli Shi
epics compiling problem 师昊礼
Re: epics compiling problem Kate Feng
Prev: Re: firewire video on RTEMS-4.6.x-MVME5500 Kate Feng
Next: RE: Frame grabber Pearson, MR (Matthew)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics compiling problem Kate Feng
Next: Re: epics compiling problem Kate Feng
