1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Motor Record - OMS58 Driver
To: EPICS Tech Talk <[email protected]>
Date: Fri, 13 Apr 2007 15:13:39 +0200
Hi -
I'm moving a stepper motor application using an OMS VME58 card:
  from EPICS 3.13.9 / motor 4.9.3   to   EPICS 3.14.8.2 / motor 6.1
In the old setup everything works fine, in the new setup the driver claims that it doesn't find the VME58 motor card. Hardware settings are unchanged, the setup call in the st.cmd is the same.
Searching the release notes of the motor record I did not find anything that I found applicable to my problem.
Before I dig into the code: Is there anything obvious that I didn't see? Similar effects somewhere?
HW: vxWorks 5.4.2, mv2100, OMS VME58, test stand with no other VME cards.
Thanks a lot!
Ralph
RE: Motor Record - OMS58 Driver Mark Rivers
Re: Motor Record - OMS58 Driver Martin L. Smith
Re: Motor Record - OMS58 Driver Ronald L. Sluiter
Prev: WebCA 1.0.0 release Matej Sekoranja
Next: RE: Motor Record - OMS58 Driver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
