1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin
To: "Andrew Johnson" <[email protected]>
Cc: <[email protected]>
Date: Mon, 16 Apr 2007 13:30:28 -0700
Hi Andrew,
I tried running make after dos2unix on asynRecord.dbd (and again with unix2dos), I get the same error message either way, so I guess it isn't a LF character problem?
Cheers,
Glen.
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, April 16, 2007 12:26 PM
> To: White, Glen Russell
> Cc: [email protected]
> Subject: Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin
> Hi Glen,
> White, Glen Russell wrote:
> > I have built epics base (V 3.14.8) successfully, but I get
> the below
> > error when trying to build asyn (v. 4-7) which I don't know how to
> > interpret. Can anyone point me at a possible problem here?
> I'm pretty sure this is a line-ending problem; your cygwin is
> probably set up to expect Unix line-endings (\n => 0x0a), but
> the file you're giving it has DOS line-endings (\n => 0x0d,
> 0x0a).  This probably explains why the error message below
> doesn't make very much sense:
> /cygdrive/c/epics-3.14.8/base/bin/win32-x86-cygwin/dbToRecordt
> ypeH.exe  -I . -I .. -I ../../dbd -I
> /cygdrive/c/epics-3.14.8/base/dbd
> ../../asyn/asynRecord/asynRecord.dbd ../O.Common/asynRecord.h
> > Error   Last token ""dbCommon.dbd""
> > input line:     include "dbCommon.dbd"
> >    in: file ../../asyn/asynRecord/asynRecord.dbd line 107
> > db_parse returned -1
> > Terminal error For input file ../../asyn/asynRecord/asynRecord.dbd
> There are various ways to solve it - changing cygwin to use
> the DOS line-ending conventions, or change the source file to
> use the Unix conventions.  If you used winzip to untar the
> asyn distribution that might explain how this happened,
> because it would have put the DOS line-endings in.
> I think we tried to fix this kind of problem in some later
> versions, but I don't know that we solved all of the possible
> locations.
> HTH,
> - Andrew
> The right to be heard does not automatically include the
> right to be taken seriously. -- Hubert H. Humphrey
Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Andrew Johnson
Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin White, Glen Russell
Prev: Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Andrew Johnson
Next: Re: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
