1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unexplained hangup in semTake(), Re: channel access security deadlock from asInit()
To: Kay-Uwe Kasemir <[email protected]>
Cc: tech talk <[email protected]>
Date: Wed, 18 Apr 2007 14:34:15 -0500
Kay-Uwe Kasemir wrote:
On Apr 18, 2007, at 14:56 , Jeff Hill wrote:
You have the thread that has the AS lock and is calling rsrv where it is
taking its lock...
If it's a classic deadlock then we need to find the other half of the bug.
I understand, but I can't get that information.
Try running the asInit command to reload the AS file in a background task spawned using the vxWorks shell's 'sp' command - that way you don't give up the shell and can run stack traces after the lockup.
You said you're seeing this on R3.14.7 and R3.14.8.2 - is there any possibility of repeating this on R3.14.9 (or with Jeff's R3.14.9 patch included at least)? I don't know the specifics of what might be happening but it might be worth trying to prove that this isn't another manifestation of the deadlock that Jeff already fixed before chasing it further.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
channel access security deadlock from asInit() Kay-Uwe Kasemir
RE: channel access security deadlock from asInit() Jeff Hill
nexplained hangup in semTake(), Re: channel access security deadlock from asInit() Kay-Uwe Kasemir
Prev: Re: nexplained hangup in semTake(), Re: channel access security deadlock from asInit() Till Straumann
Next: Re: edm: Displaying numeric information John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: nexplained hangup in semTake(), Re: channel access security deadlock from asInit() Jeff Hill
