Those commands (set_savefile_path, etc) are commands for
the autosave facility in EPICS. It appears that you have those commands in
your st.cmd file, but you did not build the application with that module
included.
Hi
Anyone understand
these error msgs. I've got the Firewire camera driver and medm screen provided
by SLS (from webpage http://epics.web.psi.ch/software/firewire/)
running, but I get some error messages in the st.cmd file as
follows:
st.cmd -- Line 18 -- Command save_restoreSet_Debug
not found. st.cmd -- Line 19 -- Command set_requestfile_path not
found. st.cmd -- Line 20 -- Command set_savefile_path not found. st.cmd
-- Line 21 -- Command save_restoreSet_status_prefix not found. st.cmd --
Line 22 -- Command set_pass0_restoreFile not found. st.cmd -- Line 23 --
Command set_pass1_restoreFile not found. st.cmd -- Line 29 -- Command
create_monitor_set not found.
I've also attached the entire
st.cmd file and the output when I run (st.cmd.out1).
I've got an inkling of what
they, but don't know where they are. I could just remove these but
may miss a feature that I want.
Thx,
Margaret
Margaret Smith
Systems Analyst
Canadian Light Source
Phone (306) 657-3580
Fax (306) 657-3535
- Firewire (IEEE1394) Camera driver - errors in st.cmd file Margaret Smith
RE: Strange channel access problem Jeff Hill
<2007>
linux with 2.6 kernel Geoff Savage
<2007>
