USR_LIBS += bspExt to the makefile. But then, since make is being instructed (why?) to also build the system on the host (linux-x86), this library was missing for the linux build. I created a dummy one using ar and the build finally succeeded. Is this the "correct" way to do EPICS with RTEMS or do I somehow have things half-configured? - John Sinclair Eric Norum wrote: Sounds like you're missing Till's 'BSP Extensions' library. Attachment:
smime.p7s
ANJ, 10 Nov 2011 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
