FWIW, I use the following sscanf format for reading IDN strings: %39
[^\r\n]
This shares the advantage of %39c in that it will not overflow an
EPICS string variable and also trims any trailing linefeed or
carriage return characters -- useful for GPIB devices which use the
EOI line to mark the end of a message.
On May 14, 2007, at 6:30 AM, Dirk Zimoch wrote:
The %c and %s input formats work like in scanf (the implementation
actually use sscanf). Thus, %s stops reading at the first
whitespace. This is probably not what you want. %39c only stops
reading after 39 characters or at end of string. For more
information see the manual pages for scanf.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Rodney R. Porter
- Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Dirk Zimoch
RE: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Denison, PN (Peter)
<2007>
2025
<2007>
2025
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
