I am learning how the SNS Channel Archiver works. I am using Vlinac as channel server. In particular I am archiving the cathodeTempM quantity. Typical value is 156.6 degF. When I look at the index file with ArchiveExport tool the value is in an undesirable format, as follows:Always a good idea. for information on how to change the format of the data. Actually, I do not know if the data is written to the data file in this uninformative format As explained in the manual, the raw data as received from Channel Access is written. For example a 'double' value. Together with meta information like suggested display precision etc. or it is the ArchiveExport tool that presents the data in that format.Yes, it's a matter of presentation. And there the problem is: If ArchiveExport (or any other tool that looks at the data) actually uses the display precision received via ChannelAccess, about 45% of all users are unhappy because they never configured the PREC fields of the records, and then miss the digits after the decimal point. If ArchiverExport on the other hand just uses some default precision, the other 45% of all the users who actually configured PREC are unhappy. Then there are the remaining 10% who deal with vacuum readings and want exponential notation, or other cases where the meta data received via ChannelAccess is insufficient. The exact percentages change every few month. As did ArchiveExport. Recent versions use the printf "%g" format as the default, because at some point in time that seemed like a good idea. Depending on your version, there should be some command-line switches to select various more specific output formats as well as an option to override the default precision: USAGE: ArchiveExport [Options] <index file> {channel} Options: ... -format <decimal|engineering|exponential> Use specific format for numbers -precision <int> Precision of numbers ... -Kay
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
