Dear Paul,
>>> On Fri, 18 May 2007 08:29:05 JST, "Paul Sichta" <[email protected]> wrote;
> Fellow CAMAC'rs,
> We're considering moving our CAMAC highways from VxWorks/VME to
> Linux/PCI.
> Would the folks who use CAMAC via Linux let me know their hardware
> configuration (mfgr/model of PCI board, SCSI interface), Linux distro,
> driver
> software, when they began using it, etc... . Hytec has something for
> this
> configuration, but I was wondering if there were alternatives.
We still keep a lot of CAMAC resources at KEKB and KEK-Linac, and
we use
CC/Net from Toyo Japan
ECC1365 from Hytec
VSD2992 from Hytec
First two provide the direct Ethernet connections. Since we had
difficulties connecting from multiple unix hosts to ECC1365's,
we limit accesses only from one host. We have to run EPICS IOC/
Gateway on that unix host.
Because of the above reasons, we also introduced CC/Net (when one
of ECC1365 was broken). It contains a standard PC inside the
standard crate controller which should be situated in CAMAC
stations 24 and 25. If you need EPICS, you can run EPICS on it,
as it runs standard Linux like FedoraCore or Debian. If you need
CAMAC performance, you can execute CAMAC transaction every
micro-second (1.04 micro-sec). Since the CAMAC cycle is one
micro-second, it is almost the limit. To my understanding the
price is around $5000 or less.
It was developed by the detector-online group at KEK, and several
accelerator projects around KEK also employ it. Some of the links
are
<http://www-online.kek.jp/~yasu/Conference/rt2003/CAMAC/RT2003-CAMAC.pdf>
<http://www-online.kek.jp/~inoue/Parallel-CAMAC/>
<http://www-acc.kek.jp/EPICS_Gr/EPICSAsia2004/PPT/Dec10/Dec10-Araki-LinuxRFGTB.pdf>
(I realize that I don't provide any documents of CC/Net at my
site...)
> Thanks,
> Paul Sichta
> Princeton Plasma Physics Laboratory
> 609-243-3477
Cheers, Kazuro.
Kazuro FURUKAWA <[email protected]>
Linac&KEKB, High Energy Accelerator Research Organization (KEK), Japan
Telephone: +81-29-864-5200 x4316, Facsimile: +81-29-864-0321
- CAMAC & Linux question Paul Sichta
Re: a problem about using EPICS DB Kay-Uwe Kasemir
Re: CAMAC & Linux question John Sinclair
<2007>
<2007>
