Till Straumann wrote: I found the following problem (tested on linux, solaris, base-3.14.9, base-3.14.8.2) with the CA client on unix: Partly confirmed on linux-x86 (Fedora-5) against R3.14.9 as follows: uranus% cau cau: get no_PV **** The executable "caRepeater" couldn't be located **** because of errno = "No such file or directory". **** You may need to modify your PATH environment variable. **** Unable to start "CA Repeater" process. error on search for no_PV couldn't open no_PV cau: While cau is still running, a ps from another terminal gives this: uranus% ps -ef | grep cau anj 1440 2430 0 09:45 pts/7 00:00:00 cau anj 1444 1440 0 09:45 pts/7 00:00:00 [cau] <defunct> anj 1446 2428 0 09:45 pts/6 00:00:00 grep cau In my case though, the <defunct> process' parent is still the original cau thread, and when the parent exits so does the defunct thread. Any long-running CA client application should be usable to prove this. In libCom/osi/os/posix we can fix the problem using Till's fix of having osiSpawnDetachedProcess() call _exit() which is a Posix.1 routine. Both vxWorks and RTEMS just return osiSpawnDetachedProcessNoSupport so there's no issue there; the other implementations of osiSpawnDetachedProcess() are for VMS and WIN32, neither of which call exit(). Another problem though appears to be that at no point does the CA client library actually fork off a caRepeater itself, even after this message appears: CA client library is unable to contact CA repeater after 50 tries. Silence this message by starting a CA repeater daemon or by calling ca_pend_event() and or ca_poll() more often. I proved that as follows: With caRepeater running, I can find the following output from netstat (NB: ca-2 is the IANA official name for our port on recent OS releases; on older releases you may have to use 5065 instead - look in your /etc/services file to see whether you have ca-1 and ca-2 defined): uranus% netstat -a | grep 'ca-2' udp 0 0 *:ca-2 *:* With cau running as above there is no output from that command. Was this functionality removed intentionally Jeff? - Andrew -- The right to be heard does not automatically include the right to be taken seriously. -- Hubert H. Humphrey
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
