I have an epics server publishing information from an osciloscope using asynRecord, and i want to take this information using Labview (8.5b). I have problem reading BINP field of asynrecord to take the points of the scope's screen (the rest of the fields are ok), i get the following error in Labview: "Warning -1950679034 occurred at Shared Variable Read in server.vi Possible reason(s): LabVIEW: (Hex 0x8BBB0006) The shared variable has no value. This warning occurred while reading \\My Computer\server\Variable1 (\\192.168.0.5\server\Variable1)" but if I use the command shell i am able to take those points. I am new to epics and labview, so i don't know in which side the problem is, has anybody have any suggestion to fix this problem? many thanks in advance Mikel Eguiraun
ANJ, 10 Nov 2011 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
