Just an update on our EtherIP with CompactLogix use: We are communicating smoothly with the PLC at this point after sorting out an anomaly. We saw that when a record scan list became long (too many records with the same scan rate), all the elements in that scan list would stop responding. Eventually we traced this down to the EIP_buffer_limit which was the default 500. This limit at 500 allows data to be sent that is 554 bytes long. After some trial and error we found that the PLC responded correctly if the data sent was 548 bytes long or less. When we set EIP_buffer_limit to 494 our problems went away. Mike Forster with John Dobbins LEPP Cornell University
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
