1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: IPac driver organisation
Cc: TechTalk EPICS <[email protected]>
Date: Tue, 17 Jul 2007 11:15:17 -0700
Title: IPac driver organisation
Hi Andrew, I’ve noticed the IPac directory contains support for a number of carrier cards.  Would it be possible to add drivers for:
xycom9660
acromag9670
hytec8002
We use these at SLAC, and we’re using RTEMS so we’ve had to OSI-ify these packages.
Also, I see drivers for a few IP cards in that directory, such as CANbus and an Octal UART card.  Is the idea that new IP drivers be placed in this directory as well?
On a related note, the GPIB IP card (IP488) is located in the Asyn directory.  Should IP modules be put under Asyn?
Regards
-doug
Re: IPac driver organisation Andrew Johnson
Prev: RE: RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
Next: Re: Asyn 4.8 compile error with Linux GPIB Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: MEDM enum not displaying correctly? Benjamin Franksen
Next: Re: IPac driver organisation Andrew Johnson
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
