1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: loading gzipped dbd, db, subs
To: TechTalk EPICS <[email protected]>
Date: Wed, 18 Jul 2007 18:49:09 +0200
Hi all,
This is for those who have already wondered how to put the huge text files (*.dbd, *.db, *.subs etc) on a small (flash) disc or how to make loading those files via network faster.
With the attached patch (for R3.14.8.2, maybe works also on other versions), it is possible to read gzip'ed files with dbLoadDatabase, dbLoadRedords and dbLoadTemplate. (Of course not gzip'ed files still work.)
(A gzip'ing installation mechanism is not included! Write one or gzip manually.)
You need zlib for your target architecture in a location where the build mechanism can find it. Here is the zlib home page: http://www.zlib.net/
Add the following line to your <base>/configure/os/CONFIG.Common.<arch> file to activate the feature for an architecture:
HAVE_ZLIB = YES
Please report it this works/fails on different architectures.
Dirk
Index: src/dbStatic/Makefile
RCS file: /cvs/G/EPICS/base-3.14.8/src/dbStatic/Makefile,v
retrieving revision 1.1.1.1
diff -c -r1.1.1.1 Makefile
*** src/dbStatic/Makefile	10 Mar 2006 14:12:49 -0000	1.1.1.1
--- src/dbStatic/Makefile	18 Jul 2007 16:28:48 -0000
*** 53,58 ****
--- 53,63 ----
  dbToMenuH_SRCS = dbToMenuH.c
  dbToRecordtypeH_SRCS = dbToRecordtypeH.c
+ ifeq ($(strip $(HAVE_ZLIB)),YES)
+ LIB_SYS_LIBS += z
+ CPPFLAGS+=-DHAVE_ZLIB
+ endif
  include $(TOP)/configure/RULES
  # Extra rule since dbLexRoutines.c is included in dbYacc.c
Index: src/dbStatic/dbLexRoutines.c
RCS file: /cvs/G/EPICS/base-3.14.8/src/dbStatic/dbLexRoutines.c,v
diff -c -r1.1.1.1 dbLexRoutines.c
*** src/dbStatic/dbLexRoutines.c	10 Mar 2006 14:12:49 -0000	1.1.1.1
--- src/dbStatic/dbLexRoutines.c	18 Jul 2007 16:28:48 -0000
*** 37,42 ****
--- 37,48 ----
  #include "dbStaticLib.h"
  #include "dbStaticPvt.h"
+ #if defined(HAVE_ZLIB)
+ #include "zlib.h"
+ #define fopen gzopen
+ #define fclose gzclose
+ #define fgets(buf,len,file) gzgets(file,buf,len)
+ #endif
  /*global declarations*/
Index: src/dbtools/Makefile
RCS file: /cvs/G/EPICS/base-3.14.8/src/dbtools/Makefile,v
*** src/dbtools/Makefile	10 Mar 2006 14:12:49 -0000	1.1.1.1
--- src/dbtools/Makefile	18 Jul 2007 16:28:48 -0000
*** 32,37 ****
--- 32,42 ----
  OBJLIB_SRCS = $(LIBSRCS)
  endif
+ LIB_SYS_LIBS += z
+ endif
Index: src/dbtools/dbLoadTemplate.y
RCS file: /cvs/G/EPICS/base-3.14.8/src/dbtools/dbLoadTemplate.y,v
diff -c -r1.1.1.1 dbLoadTemplate.y
*** src/dbtools/dbLoadTemplate.y	10 Mar 2006 14:12:49 -0000	1.1.1.1
--- src/dbtools/dbLoadTemplate.y	18 Jul 2007 16:28:48 -0000
*** 20,25 ****
--- 20,33 ----
  #define epicsExportSharedSymbols
  #include "dbLoadTemplate.h"
+ #include "zlib.h"
+ #define read gzread
+ #define fileno(file) file
+ #endif
  static int line_num;
  static int yyerror();
Prev: RE: IPac driver organisation Andy Foster
Next: Mantis Bug Tracker Fixed Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
