1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to declare the command array?
To: zhangdemin99 <[email protected]>
Date: Thu, 19 Jul 2007 11:46:49 -0500
I presume that you are using devGpib and ASYN. I think that the following command table entry will do what you want:
{&DSET_SO,GPIBWRITE,IB_Q_HIGH,NULL,"DISP:TEXT '%s'",200,NULL, 0,0,NULL,NULL,NULL},
Then in your st.cmd file you would have lines like:
asynOctetSetInputEos("L0",0,"\n")
asynOctetSetOutputEos("L0",0,"\n")
If you want to include a single quote character in the displayed message you must send it as two adjacent single quote characters, or you can change the command above to
{&DSET_SO,GPIBWRITE,IB_Q_HIGH,NULL,"DISP:TEXT \"%s\"",200,NULL, 0,0,NULL,NULL,NULL},
(then you'll have to send a double quote twice to get it into the displayed message......)
On Jul 19, 2007, at 8:38 AM, zhangdemin99 wrote:
Dear all,
I am using ASYN to communicate the GPIB device, and a serial line directly attached to the IOC. I want to send a string command to the GPIB device, such as "DISPlay:TEXT" ,and the text which I want to send is anystring, then how to creat the command array entries when creating ? the "eos" is "LF".
Many thanks in advance.
demin zhang
CAEP
轻 轻 的,大 话 3 来 了。赶 快 收 拾 行 囊,开 始 我 们 的 探 营 之 旅 吧!
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
How to declare the command array? zhangdemin99
Prev: Re: How to declare the command array? Emmanuel Mayssat
Next: medm with epics-base 3.14.6+ Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
