1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Archiver | Matlab
To: tech talk <[email protected]>
Date: Fri, 03 Aug 2007 16:19:51 -0400
On Aug 3, 2007, at 15:51 , Eric Berryman wrote:
Hello!
I'm having some problems with the Matlab part of the Channel Archiver.
 Everything compiles (mex) fine in the /Matlab directory (make
matlab), but when any of the matlab commands are executed in matlab
(example: ml_arch_plot), I receive the following error:
??? Invalid MEX-file
'/opt/epics/extensions/src/ChannelArchiver/Matlab/O.linux-x86/ ArchiveData.mexglx':
libdbStaticHost.so: cannot open shared object file: No such file or
directory.
Maybe you need to set LD_LIBRARY_PATH to the location of your EPICS base lib directory.
How serious are you about using that MEX interface to the archiver?
Is anybody else actually using that?
For what it's worth, and still on the experimental side,
I myself have started to directly access the archiver's
network data server from Java, and then in turn use that
java code from within Matlab, since Matlab can now invoke
java code in jar files without any of that MEX trouble.
As for details on how to access the archive from Java:
The "Control System Studio" includes a java API for
accessing various archive data sources.
A snapshot that includes the ChannelArchiver data server
is on http://ics-web4.sns.ornl.gov/css.
Get src.tgz,
unpack,
and check org.csstudio.archive.channelarchiver/channelarchiver.jar
and examples in org.csstudio.archive.channelarchiver/matlab.
-Kay
Channel Archiver | Matlab Eric Berryman
Prev: Re: Channel Archiver | Matlab John Dobbins
Next: RE: "invalid UDP request" during boot Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Enabling drvLinuxGpib (linux-gpib) Emmanuel Mayssat
