1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ArchiveDataServer - signals appear to stop changing after run of update_server cron job
To: [email protected]
Date: Mon, 6 Aug 2007 15:58:49 -0400
Hi All,
We are running the 08/29/2006 snapshot of the Channel Archiver and currently have the same system archiving and serving data. We've started to notice that every-time the update_server cron job runs and actually has something to update, signals viewed with the Java Archive Viewer appear to stop changing for various amounts of time. If we recreate the affected master_index (remove master_index and indexconfig.xml files from /arch/data; execute /arch/scripts/ update_indices.pl) everything looks normal.
For example, this first screenshot of the archive viewer was taken after the update_server cron job ran at 15:01. Note that normal behavior seems to resume at different times between 15:02 and 15:09.
PNG image
And the second snapshot of the same data was taken after rebuilding the master_index.
PNG image
Could this be the result of some problem in our setup or configuration? Any suggestions for avoiding this would be greatly apprecited.
Many thanks,
Devin
Devin Bougie
Laboratory for Elementary-Particle Physics
Cornell University
[email protected]
Prev: RE: "invalid UDP request" during boot Jeff Hill
Next: Re: Enabling drvLinuxGpib (linux-gpib) Gasper Jansa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: problem in communicating to the gpib device with asyn4-6 Eric Norum
Next: Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
