1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RTEMS access VME bus
To: [email protected]
Date: Tue, 14 Aug 2007 10:39:35 +0800
   now I'm trying to access the vme bus with RTEMS. first I translate a
known VME address into a CPU address with BSP_vme2local_adrs(unsigned
address_modifier, unsigned long vmeaddr, unsigned long *plocaladdr), and
then I want to test whether the board exists with a function, e.g.
rtmsDevWriteProbe or rtmsDevReadProbe, but I can't find the two functions in
RTEMS4.6.0, any function to test? thanks!
Haoli Shi
Prev: Re: problem in communicating to the gpib device with asyn4-6 Eric Norum
Next: RTEMS access VME bus 师昊礼
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "build" make target now installs Tim Mooney
