1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dm2k not compiling :(
To: TechTalk EPICS <[email protected]>
Date: Tue, 14 Aug 2007 12:37:19 +0200
I have many problems getting dm2k to compile
first of all under graphX/printUtils in dsimple.c:
I had to remove the char*malloc; stuff
Added stdlib.h include.
Also had to fixup char*calloc; somewhere .
Then it had #include <xpm.h>
So I had to make a symlink to X11/xpm.h
then in resourcePallette.c:
I had to add: define FLDNAME_SZ 4
as for some reason it doesn't get that from the correct .h file..
even if I add #include "dm2kCdev.h" ??
And now finally it breaks on:
g++: /usr/lib/libdld.1: No such file or directory
here is the last part of the output from running make:
make[2]: Entering directory
`/home/heinrich/EPICS/extensions/src/dm2k-2.5.3/dm2k/O.linux-x86'
make[3]: Entering directory
../Makefile.Host:410: warning: overriding commands for target `dm2k'
/home/heinrich/EPICS/base-3.14.9/config/RULES.Host:428: warning:
ignoring old commands for target `dm2k'
g++ -ansi -pedantic -o dm2k -g  -Wall -Woverloaded-virtual
-Wwrite-strings -Wconversion -Wpointer-arith -Winline   -I../../graphX
-I../../xc -I. -DCONFIG_NO_TEAR_OFF -DPROMPT_TO_EXIT=0 -DBUILT_AT="\"Tue
Aug 14 12:34:32 SAST 2007\"" -DBUILT_BY="\"heinrich\""
-DDM2K_HELP_PATH="\"http://help.bessy.de/Dm2k\""; -DUSE_XPM
-I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11/X11
-I/usr/X11R6/include -I/usr/X11R6/include/X11
-I/usr/contrib/X11R5/include -D_X86_ -Dlinux -fPIC -D_REENTRANT  -DUNIX
-D_BSD_SOURCE -DEXPL_TEMPL -I. -I..  -I../../../../include/os/Linux
-I/home/heinrich/EPICS/base-3.14.9/include/os/Linux
-D_POSIX_C_SOURCE=199506L      -L../../../../lib/linux-x86/
-L/home/heinrich/EPICS/base-3.14.9/lib/linux-x86/ /usr/lib/libdld.1
-Wl,-rpath,/home/heinrich/EPICS/extensions/lib/linux-x86
-Wl,-rpath,/home/heinrich/EPICS/base-3.14.9/lib/linux-x86
-Wl,-rpath,../../../../lib/linux-x86 actions.o amDialog.o browserHelp.o
callbacks.o channelPalette.o colorPalette.o display.o dmInit.o
eventHandlers.o faceplateBase.o faceplateGUI.o faceplateGUICallback.o
faceplateDm2k.o getArchiveData.o help.o help_protocol.o dm2k.o dm2kArc.o
dm2kBar.o dm2kByte.o dm2kCartesianPlot.o dm2kChoiceButtons.o
dm2kCommon.o dm2kComposite.o dm2kControl.o dm2kDelay.o dm2kDynSymbol.o
dm2kImage.o dm2kIndicator.o dm2kMenu.o dm2kMessageButton.o dm2kMeter.o
dm2kMonitor.o dm2kOval.o dm2kPixmap.o dm2kPolygon.o dm2kPolyline.o
dm2kRectangle.o dm2kRelatedDisplay.o dm2kShellCommand.o dm2kStripChart.o
dm2kText.o dm2kTextEntry.o dm2kTextUpdate.o dm2kValuator.o dm2kWidget.o
objectPalette.o productDescription.o resourcePalette.o shared.o
updateMonitors.o utils.o xgif.o clipbd.o dm2kCA.o    -lJpt -lXpm -lca
-lCom -lUnix -lANLwidgets -lPrintUtils -lGraphX -lXm -lXt -lX11 -lXext
-lXmu  -lm -lXp -lSM -lICE -ldl   -lpthread -lreadline -lcurses -lrt
-lm
make[3]: *** [dm2k] Error 1
make[3]: Leaving directory
make[2]: *** [dm2k] Error 2
make[2]: Leaving directory
make[1]: *** [buildInstall.linux-x86] Error 2
make[1]: Leaving directory
`/home/heinrich/EPICS/extensions/src/dm2k-2.5.3/dm2k'
make: *** [dm2k.buildInstall] Error 2
I'm not trying to compile with CDEV
I do have: /usr/lib/libdl.so ect
what is libdld ?
-Heinrich
RE: dm2k not compiling :( guobao shen
Prev: RTEMS access VME bus 师昊礼
Next: a technicality ? Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: RTEMS access VME bus Mark Rivers
Next: RE: dm2k not compiling :( guobao shen
