1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: StreamDevice protocol question
To: "Shepherd, EL \(Emma\)" <[email protected]>
Cc: [email protected]
Date: Mon, 27 Aug 2007 10:29:59 +0200
Hi Emma,
I found the bug in StreamFormatConverter.cc.
In StdCharsetConverter::parse() (line 387), replace
    info.printf("%%%d[", fmt.width);
with
    info.printf("%%%s%d[", fmt.flags & skip_flag ? "*" : "", fmt.width);
I will put a patch on the StreamDevice website.
Dirk
Shepherd, EL (Emma) wrote:
I've been battling with a Streams protocol and thought I would ask for
some advice from the experts!
I have the following input from my Streams device: "RC1C0V0.00E2.50"
Now this is just an echo of a command I have sent so instead of saving
the information I want to use the * modifier to simply skip the floating
point numbers, like so:
in "RC1C0V%*[.0-9]E%*f";
(NB: I am using a charset instead of %f for the first number since the E
character could be interpreted as an exponent).
This doesn't work, and I get the following Streams error:
2007/08/23 09:07:49.260 BLXXI-EA-LED-01:CH1SENDOUTPUT: Input
"RC1C0V0.00E2.50" too short. No match for "E"
However, if I remove the * modifiers and put field names there instead,
it works fine:
in "RC1C0V%(MYRECORD.VAL)[.0-9]E%(MYRECORD.VAL)f";
If I leave the field name in for the first number and %*f for the second
I get the following error:
2007/08/23 09:25:25.632 BLXXI-EA-LED-01:CH1SENDOUTPUT: Input "2.50" does
not match format %*f
Any ideas why I am not able to use the * flag in these cases?
Emma
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
</FONT></DIV>
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
StreamDevice protocol question Shepherd, EL (Emma)
Prev: Alarm Handler Umashankar Panda
Next: Re: bug in Red Hat Linux g++ 3.2.3 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: StreamDevice protocol question Shepherd, EL (Emma)
Next: ethernet IP John Sinclair
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
